Dynamat
Dynamat
I was thinkin bout purchasing dynamat and found that it is sold at a local tweeter store, in bulk packs of 36 sq. ft. for 250 dollars. But i have used the search feature, and have read that other people are puttin in 70 sq. ft. at least, and have bought that for 100 dollars. I would like to kno where they got it that cheap. I found some on ebay, but thats 100 dollars for 36 sq. ft. Any info will be appreciated.
Josh
Josh
If you want to deaden the whole cab, get 1 xtreme bulk pack. You should be able to find them on ebay fairly cheap. 1 complete layer should be more then enough. Should you still need it more quite, Cascade engineering makes a lead plate liner to cover the floor board. It's basically a thin lead sheet stuck between 2 pieces of foam insulation. It also adds more padding in the carpet for comfort.
http://www.raamaudio.com/
I highly recommend this stuff. Works great, and much cheaper than Dynomat. I used it in my '02 Eclipse one roll basically did from the B pillars back, and I still had some left over. I plan on getting another roll one of these days for my truck, and if I ever get off my lazy butt I want to use the leftovers from the previous roll to do my doors...
This is the stuff that i just order, should be here this coming week and i'll install it over thanksgiving. Fatmat I got this kit specifcally:Rattle Trap
Originally posted by ken800
www.b-quiet.com
brown bread is equivalent to dynamat extreme and is quite a bit cheaper...
www.b-quiet.com
Email me if you want some pics of the install.
-Kimball
