K&N Oil Filter any good?
K&N Oil Filter
I've been using them for a couple years now, they're excellent. The 1 inch nut on the end makes it real nice for removing and replacing. I'm not concerned with spending 9 bucks for a filter after spending 31 G's for the truck and then another 20 G's in mods. I say yay !!!!!
Konig,
I have to agree that the K&N is overpriced. (Paying for their name) The nut gimic even, is not worth all the extra $. Guess if you are foolish enough to change synthetic oil every 3,000 miles as some do and waste those $ you might just as well waste a few $ more for the K&N name and there nut on the bottom filter..
The Motorcraft FL 820S has been tested over and over and proven to be a very respectible filter. A filter also recommended by Ford. Personally, I'd go with the Motorcraft FL 820S oil filter and use the extra $ toward the purchase of a Motorcraft FG 986B fuel filter which should be changed fairly frequently.
Originally posted by Konig
a strap wrench works better than the "nut" does.. 9 bucks is of course pocket change for just about everyone on here, I just ask my self... "Is the K&N 9 times better than the 820-s MC filter?"
nah, not even close... oil only gets so clean...and we change it every 3k anyhow
To change synthetic oil at 3,000 mi. is really wasting resources and $ . Personally, I change my Mobil 1 and filter at 6,000 miles. I have a strictly street driven '03 Lightning that gets the occasional WOT spurt. I live in NY and not the desert. I'm sure there are those that will say my changing my synthetic at 6,000 miles is overkill. Changing at 3,000 miles would be ridiculous.
http://neptune.spacebears.com/cars/stories/mobil1.html
I race my truck and drive it every day.... 30 bux is oil isnt a big deal every 3k miles... sometimes I do push it to 5k if I havent been hard on her.
The color of the oil goes from dark brown (3k miles) to black at about 4.5-5k miles...if you dont run it down the strip anyhow.... if its black its getting changed...
does the oil keep coming out when you take the filter off? I have always drained everything before taking the filter off... a lot comes out even with it drained first
As far as changing oil by sight, that's not a very good indication of oil at all. Many oils will turn dark fairly quickly and still have a lot of useful miles left in the oil. Oil analysis is the only true indicator of a condition of an oil. 3,000 to 5,000 miles on conventional oil and 5,000 to 7,000 miles on synthetics should be easily attainable.
