Alcohol Injection ??
Hey Guys....I had some questions about Alcohol injection. I know there are a few of you out there running it. But my question is what kinda performance gains would it provide on a stock motor....I dont have any mods other than JLP Ram Air, and Magnaflow Cat-Back Exhaust as I cant afford to lose my warranty, but I was toying with the idea after its up. I know it allows for more timing and more boost on pump gas but what else does it exactly do ??? Will it be bad for a stock motor ? Does it give any extra HP just by itself without the boost and timing increases ?? I really only want to go Low, Low 12's with the truck....I know plenty are doing it without the kit, but I figured it might make things a lil easier......Can Anyone give me some detailed info on this ??
Thanks in Advance
Josh
Thanks in Advance
Josh
Unless you're lean now, you won't get much of a power increase with the alcohol injection until you up the timing and/or boost; probably lose some do to the alcohol adding extra fuel and richening the A/F. The alcohol gives some additional fueling and octane increase, some air temp decrease, but does most of it's work in the combustion chamber allowing you to run higher timing and boost on pump gas. On my truck there is a 30 rwhp and 40 rwtq difference between my street and race settings in the computer. I want to run close to the race numbers on the pump gas. This allows that. By the way. I bought the SMC kit which is a VERY professional kit with a lot of adjustability, safety features, plus they include a stock windshield reservoir with the pump inside for a very stock looking install.
By the way, thanks Easterisland for the tip and helping to get this kit out on the market!
Jody
Jody
A blown stock block. I think a 6#'r and a 75 shot is pushing the limits of your block, but that's just my opinion....I imagine Rob will chime in and tell me I'm wrong, lol, but I think he is the exception to the rule, not too many guys have gotten away with bigger pullies and nitrous on the stock block....
Alcohol Injection
I wouldn't mind trying this setup one day if it will increase my performance. I believe I'm pushing my stock engine to the limits these days.
BlackBeast 99
467 rwhp
688 rwtq
https://www.f150online.com/galleries...y.cfm?gnum=720
BlackBeast 99
467 rwhp
688 rwtq
