Installed my Factory Tech Valve Body
Originally posted by billarf
By the way, I as you stuck with the stock tranny pan and Gregg said that was a ok. I opted to stay with the stock pan as I am in NY and also did not want to wave a red flag to the dealership that I had a FTVB..
Lets just hope they don't have to take it for a test drive
Thanks for your help billarf, thanks everyone
You got to remember, the 60's + 70's pretty much took away
most of my brain Cells, so sometimes I don't see what I'm reading
Checking tranny fluid level
Proper way to check tranny fluid level:
1) Have your glasses on so you can see the dipstick marks
2) Tranny fluid should be HOT
3) Truck on level ground
4) While engine is running/ vehicle stopped with foot on brake, work the tranny through all gears to include reverse.
NOW .........................
5) Check dipstick level while tranny fluid is hot, truck is level, engine running while truck is in neutral.
Originally posted by Rob_02Lightning
The instuctions said 5, but I wanted to be safe,
so I checked it, I first drained the pan into a 1
gallon empty antifreeze container, then there was
only a little left in the pan, (maybe 1QT).
I bought extra fluid, I'll take it for a nice calm ride
later and then check it again, Thanks.
Mike
Originally posted by InS0mNiAc
just wanna bring it up again about the line
pressure Rob, is it increased over stock?
NOT A LOT THOUGH, just a tiny bit,
I'll talk to Johnny about it after I get a little more
seat time in and see how it is.
I've had early programs that had transmission pressure
increase and I hated them. I gave up at least two or three
because it banged or shifted not to my liking.
My current Chip IS NOTHING LIKE THAT, just a tiny bit of
tranny tweaking by Johnny, it was a tad more positive than
stock. Maybe more of a duration between shifting change,
than a pressure change. I remember something about 200MS.
No sweat, I aint gonna go hot rodding around testing it out. Schitt, I didn't even WOT it yet. Tommorrow we got Jeep plans and a party to go to, but I'll get some seat time in and see if it's too much. If it is, I'll talk to Johnny, and we'll fix it, thats all.
Rob, Mine took 7ish quarts in the end. FYI
I think I understand your feelings on the harshness? This does tend to be a subjective matter. When your 19 yrs old, if it did'nt break your neck it was'nt a "solid shift". And when your old a 4 door family car is too firm. I take it your wanting a normal driving session to not bark the tires?
Just talk to Gregg. I know he's customized VBs for people before.
And I installed mine before the chip/dyno tune and also before the converter. At 1/2 throttle it would give a solid bark but not go sideways.
One thing I really really like now is the converter. At about 50% throttle. It's "there" durning the shift but not harsh or tire chirping like it used to be. It give a nice solid fwd movement with out feeling a bang. And when at the track sometimes after a good 1 hour cool down it'll bark my ET streets. The converter has my 100% approval because I still get the best of both worlds. Softer under easy driving and all out on the strip.
Rich
Rich
Thanks Rich,
GREAT INFO
HAPPY HOLIDAYS BTW
I got to assume the low 40's hi 30 degrees had something
to do with it spinning so much last night, plus I do have a tiny
bit of tranny tweaking "via the Chip" than can be removed
if need be.
But ya, part of my Love for this vehicle, has been also
to run 12.8 on F-1's (I see your a champ at that too)
12.7's on Hoosiers
and to hit a switch and turn that into an 11.8 w/Hoosiers,
while still maintaining 100% of the factory comfort, and
the original exhuast and suspension.
I am very happy with the results and think with some more
seat time, and MAYBE the chip tweaking taken away,
THIS IS GONNA ROCK
GREAT INFO
HAPPY HOLIDAYS BTW
if need be.
12.7's on Hoosiers
THIS IS GONNA ROCK
Originally posted by Jubelands
Congrats on the succesful install Rob. Just a random question, but does anybody know how the 2CR valve body can be purchased. I'm getting used to the 2C version and feel that i need a stronger shift.
You can get a 2CR from me, da Chiken Man! Give me a call. Phone # on website.
Tim
Originally posted by Chikenears
Jubelands,
Tim
Jubelands,
Tim
Mine came from you I believe ?
Vinnie bought it with that Monster Tranny in a Box Deal
Schitt, I already added you as the Vendor on my Mod page
and everything, I hope it came from you
http://www.geocities.com/robs02light...rformance.html
Re: Installed my Factory Tech Valve Body
Taken the pan down without draining it (yes I reused the fac pan)
was not as bad or messy as I thought.
Good job on getting the FTVB in, and glad ya like it. I love mine.
Shane
