Still getting the SES light,,, help
I recently got a new exhaust for my 2002 Lightning. I decided to buy all the parts to make my own kit. I bought two Borla XR-1 Sportmans Race Mufflers and a X pipe. I went to my local muffler shop and got a new 2 1/2 dual exhaust with no cats. Its sounds extremely aggresive and very loud. Love them new chrome tips.
I knew I was going need O2 similators to trick the computer that I had working Cats......so I got them as well and install them the same day I got my exhaust, I got SES light the same day. I blamed the similators so I got new pair from a different company and the same thing happened after I drove my truck for a while.
What do you guys think is my problem?
Originally posted by teamsvt2002
With the new O2 similators that I got I am only getting one code that is causing SES light to come up. T
The code is PO 136.....O2 sensor Bank 1 sensor........
How do I fix this?
How do I fix this?
FWIW a 136 is a o2 sensor malfunction. so either the mil is not working or the one that is functional failed.
How do I fix this?
How do I fix this?
PO136:
HO2S Sensor Circuit Malfunction (HO2S-12) Detailed Description
The downstream HO2S sensor(s) are continuously checked for maximum and minimum voltages. The test fails when the voltages fail to meet the calibrated limits.
Possible Causes
Pinched, shorted, and corroded wiring and pins.
Crossed sensor wires.
Exhaust leaks.
Contaminated or damaged sensor
HO2S-12 stands for Heated Oxygen Sensor bank 1 sensor #2.
in english, this means the passenger side catalyst monitor or downstream hego on the right hand side of the vehicle is doing it's job, it knows your cats aren't there and your "MIL eliminators" are crap.
good luck.
later,
chris
