Alcohol injection guys
This is for all you guys out there that are using alcohol injection on your trucks. I've been reading a lot about alcohol injection on a lightning and it sounds like a great idea for my situation.
I am just wondering if you guys that have it could post some pictures of your set-ups. And also if you could tell me what brand you guys use and how you like it.
I'm using the SMC kit. Uses a stock wiper washer bottle with the pump installed inside. Very easy to hook up and hard to see after installed. I'm running 19 degrees of timing on 91 octane gas.
Sorry, no pics yet. Lost the camera hookup to load into the computer. Here's his site:
http://www.smcenterprises.com/
Jody
Jody
Jody
Jody
Anyone else with any pics of different set-ups?
Originally posted by RDY2RAC
if you plan on racing in the nmra i would suggest you consult the rule books as its not aloud to be on the truck period. i know a few trucks were running it last year and seam to have had good success. good luck with it.
Another question, is it safe to run such a high degree of timing on a stock block or would the extra timing cause the motor to blow??
And also how much does the lightning specific kit go for, the one which replaces the washer fluid?
