High transmission temp ?
I got a 2000 Lightning a year and a half ago and have been reading a lot of the post archives on this site for a while. a few weeks ago I installed a tripple gauge pod with the lunar series gauges, and they are great. I have a question, though, on the transmission temperature... from reading the posts, I am under the impression that normal operating temp is about 180 ... and that cooler is better. the part that worries me is that my trans temp gauge shows that the trans temp eventually gets up to, and stays at, 250 (!!!) during an hour of normal driving (mixed highway and back road)
I am thinking that this is really bad and not normal, even for stock. I mounted the temp sender in the suggested spot (the access hole on the driver's side)
Also, the stck engine temp gauge shows that the engine is at the normal operating temp... Other than the high trans temp reading, the truck drives perfectly. In addition, I just had the trans fluid changed a month ago.
Does anybody have an idea of why it would make so much heat under normal driving (no burnouts or anything)? or is this really normal for a stock truck ?
thanks for the help
thanks for the help
Ed,
thanks for the idea about grounding the gauge... it is a good one. I put a wire from the base of the temp sender to the bolt that atttaches the oil filter bracket to the engine. the resistance between ground and the temp sender base went from 3.3 ohms to .4 ohms. I took the truck for a test drive and the temp still got to 210 in 15min of moderate driving... still too high, I think. perhaps the sender is still not grounded properly. Where did you run your ground wire to ??
tb,
the temp doesnt seem to change much no matter how hard I drive. the temp just slowly climbs into the 200s.
kj
tb,
kj
Ed,
tb,
kj
tb,
kj
The instructions say you don't, so I don't know if you did or not, but that made the difference in mine
Ed,
tb,
kj
tb,
kj
Normal temp in the winter is 110-150 highway/some stop and go. Summer 170 anything over 190 will start damaging the trans. Its a good idea to run a larger pan, preferably the FMS one that has cooling fins and holds an extra 4 qrts of fluid to help keep temps down. KJJ you said you just had the fluid flushed, check to make sure theres enought fluid in there, maybe they didnt top it off all the way. Engine running and at opp. temp when checking. Hope this helps
