What is the best PCV KIT
Originally posted by RED 92
yes thats it. Its an exact fit ..
.. It will provide a very small amount of reverse flow under pressure, I dont think you have the strength to blow through it, (maybe you do j/k)but you can certainly blow through the stocker as designed.
Do you know were to install the dime ?
Thanks for the help guys
It was real easy to do. I got the new Pcv valve "Ev-98-B'" or "D9ZZ-6A666-A" for a mustang. From what I here is that it is for the 03 Cobra. I just took old Pcv out and put new one in, and installed a dime (with a small hole drill in it) on the top of the PCV tube right before the intake.
Old one is not a very good design "EV-233" You can blow air through both side of this thing. This is what causes the oil to build up into the intake area of the superchager
NOSUPRISE,yes I put the dime at the upper plenum.some say to drill a small hole in the dime,so I did and at idel it would miss.so I put a dime with no hole in it and the miss at idle went away.Funny thing is I can put the stock PCV valve 233 in and theres seems to be no change engine idle vs the new Pcv valve EV-98. (?) I have a 99 f-150 with the 5.4l V8 and it has the same stock PCV valve 233 that the Lightnings have.why would it be on a N/A engine it would just blow-by it to under WOT.Just asking ?s
THANKS
JR2000
THANKS
JR2000
