Coolant in the 03?
THAT IS MOTORCRAFT PREMIUM GOLD COOLANT
That is motorcraft premium gold coolant already mixed DO NOT mix this with any other kind of coolant I have found that this is the best for our intercoolers the chemicals that motorcraft has added to thier coolant for our supercharges it works sure it is higher in cost but it is well worth it [no i don't work for ford] Stay away from prestone for intercoolers they will run hotter also any type coolant such as you find for lower temp of your supercharger at speed shops stay away from that also>UNLESS yours is a raceer all the time You can't go wrong with motorcraft premium gold coolant there was a PERVERT awhile back that mixed alcohol with intercooler coolant dumb *** didn't know any better i guess. If you don't have JDM heat exchanger i recommend you get one it makes no difference if you race you lightning or not you should install one the hot summer temperature will be here soon just my.02 worth Also rob-02 lightning has a vast knowledge on lightnings check with him on this he knows what works and what doesn't.:thumbsup
nope.
actually, it is indeed CAT ****!
also ford recomends adding bottle of this with every coolant service.
go figure?
j/k
on an interesting side note, doing a google image search for the words "cat ****" will not find you anything, but searching the words "cat urine" will find you a hot picture of thora birch!
go figure again???
go figure?
j/k
go figure again???
DAM BOY YOU GOT BAD BREATHER
Originally posted by superfords
nope.
[IMG]http://www.arcatapet.com/fullsize/6289.jpg[/IM
j/k
go figure again???
nope.
j/k
go figure again???
Re: THAT IS MOTORCRAFT PREMIUM GOLD COOLANT
Originally posted by tlfwatch
I have found that this is the best for our intercoolers. Stay away from prestone for intercoolers they will run hotter also any type coolant such as you find for lower temp of your supercharger at speed shops stay away from that also>
