Tried the Cherry Wax
THANKS DAVE
Unfortunatly it started getting dark when I finished
so the pictures don't show how good it came out, No strong Sun to reflect much.
Worse than that I noticed some really bad spots on the Lightning
where the paint looks sand blasted (&^$@#($@(#))@())(!@$!!#
Of course the lower front ground effects, especially @ the fog lights, and a weird spot on the pass side back, right before the wheel wheel, like little pin ******, tons of them *#*#$*!#*(@#$(#@
Can't see it unless your up on it, BUT STILL (!$#(!$#(!#$
Anyway the cherry wax goes on like butter and comes off
like nothing, it truly made a difference and I took almost identical pictures at the same time of day in the same spot where you truly can see a difference
The NON CHERRY WAX pic's were after a Mcquire (spelling) detail
So both are "right after" detail pictures
Miracle Mist
This waterless soap is formulated to remove dust, light dirt, bugs, finger prints and also to assists you when using the clay bars. These products will not scratch and leave a brilliant shine. A wonderful item to use on a daily or weekly basis in the in going effort to help maintain your finish. Can be used on paint, glass and chrome. Just spray on, wipe once, turn the towel over and buff dry. You’ll won’t believe the shine.
Get yourself a gallon of this while your there...A coat of this on top of the CWW and you will think your truck has been covered with glass!!!
