when installing the pan is there a space cut out behind the plate, like with the stock bumper there is a hole behind the plate, and if so, is it in the same place as the stock..This is why, will i still be albe to use this setup...
Most Rollpans come with a hole behind the plate for Hidden Hitches. If not the fiberglass ones are easy enough to cut and the Metal Sir Micheal already has a hole for a hitch.
Since your hitch is a OEM custom set-up I do not know if the holes will line up. But they should.
