Intercooler pump operation??
Well...
Bob:
It runs all of the time, starting shortly (30 seconds or less?) after vehicle start, as long as one of the measured inlet temperatures (I think IAT2) is above a critical level (60 degrees F, I think).
If it's really cold out and you just start the truck and let it idle, the pump won't come on for quite a long time. Whack the throttle a couple of times hard, and the intake temperature will get high enough to trigger the pump. Ditto also if you let the coolant come up to temperature - you'll get enough heating throuout the intake to trigger the pump.
If it's warm out, the pump should come on shortly after starting the truck.
Your tuner should be able to adjust the temperature at which the pump comes on, if it's an issue with you.
Real-world, the trigger point of the pump really doesn't come into play. If the engine is warm at any realistic air temperature, or if you build any boost, or if it is above 60 degrees or so outside, it will be running.
