What shackles ?
I think a lot of people are running the JLP 3" shackle on the 03-04 trucks. I think i might try them on my 01 and take a leaf out to get the 4" rear drop i want.
www.johnnylightningperf.com
Originally posted by Tim Skelton
I would limit the amount of shackle drop you add. The longer the shackle, the more it allows the rear axle to shift around when cornering.
That being said, shackles are cheap and generic. Take your pick.
so would i be better off with my 2" shackles a just remove a leaf? Or should i get the h anger kit to achieve a lower drop?
I have an '03 with the JLP shackle. I used the 4" hole and I sit pretty level. I put a 2" shackle on it first and then removed them because you couldn't see any difference. I have no issues with ride quality or handling. Just remember you will have to flip the direction of the shim when you add the shackle. Hope this helps. Here's a before and after shot, you be the judge.
Before:
After:
Before:
After:
Originally posted by 2003supercrew
Where do you buy the 3" JLP shackle? Also I've noticed people buying 2", 3" and 4" shackles. Are all these different or is it just one shackle with different mounting holes?
