Missing at part throttle/cruise speeds
For the last few days my truck has had a miss at part throttle or cruise speeds. It only does it at real low throttle input no matter what the speed is. I checked and cleaned the IAC or IAT whatever it is but it didnt help. Everything is fine at idle and more than low throttle input. I was thinking maybee the mass air sensor or a fried plug but im not real sure.
FYI: Slight tip in throttle seems to be more of a lean mixture. That may have some bearing on your diagnostics...
I would have said fuel pump, but when mine cracked (the outlet of the pump) it went from poor part throttle, to almost unable to drive it. There's a low and high speed setup on the fuel pumps.
This all started when i added the ported eaton. So i guess it leaned it up at Tip in. But doesnt the computer add more fuel when neccassary at tip in? Im in for a reburn now anyway since im puttin a 2.8 upper on tommorow and filling up my bottle for the first time
oh and im running ngk tr6's @ .035
Originally posted by navyguy0023
Mine does this too. I changed out my Denso IT20's for NGK TR5's and it got better for a day or so then it was back worse than ever. I suspect its the plugs or O2 sensors. I have IT22's on order and new Denso Sensors too, hopefully that will solve the problem.
Eric
Black 99L
Eric
Black 99L
