Will a pan hard bar help?
Under road racing conditions at a moderate steady turn at 80mph or so, if I apply the brakes moderately the rear end likes to swing out. How much will the pan hard bar help ? Or is this more an issue of the poor weight distribution for the lightning?
Here is what i have
Roush suspension
2 inch belltech shackles
shock extenders
Here is what i have
Roush suspension
shock extenders
What do you mean exactly by "swing out?"
If you are talking about oversteer, I would not think that the PHB would help much. If anything, as I understand its effects on roll center, the Ruslow PHB will contribute to oversteer (which, for most front-heavy trucks, is not a bad thing).
The PHB is to steady the axle so that the rear doesn't get squirrely in transitions and so the geometry doesn't get blasted out on high-G turns.
If it is oversteer, there are any number of things that can be done to correct that. Some more detail would help.
Also, your best bet would be the road racing forum at NLOC.
Originally posted by player19
Tim,
It is oversteer like you stated. What other info do you need? What steps are available to correct oversteer? I am sure that weight relocation is one
Tim,
Understeer/oversteer is a super complicated subject, but there is a ton of info out there.
The first place to start is tire pressure. Run some more in the rear and see how it feels.
Maybe the Hotchkis anti-sways that I run account for some of the difference between our trucks. It's an expensive experiment, but they will help the handling anyway.
Here's a nice summary that I stole from the Web:
DECREASE UNDERSTEER..... CORRECTION.....DECREASE OVERSTEER
higher pressure........................tire pressure - front......................lower pressure
larger contact area....................tire section - front...............smaller contact area
more negative.........................wheel camber - front.......................more positive
softer............................................ springs - front.........................................stif fer
thinner (softer).............................sway bar - front.........................thicker (stiffer)
larger...........................................s poiler - front.......................................smalle r
lower pressure.........................tire pressure - rear.....................higher pressure
smaller contact area.................tire section - rear..................larger contact area
more positive.........................wheel camber - rear......................more negative
stiffer........................................... .springs - rear.........................................softe r
thicker (stiffer).............................sway bar - rear.........................thinner (softer)
smaller..........................................s poiler - rear........................................larger
weight bias rearward................weight distribution..............weight bias forward
