Plug Gap? (Help me finish this chart)
#47
#52
Great post re-visited
One thing no one seems to talk about is,
whats good for me MAY NOT be good for you,
(even if we have identical mods)
For instance my truck ran like total schitt with TR-6's from the second I installed them, yet for others they Love them.
My truck runs amazing with Denso IT-22's, yet other's
don't like them.
and so on......
Mine are gapped at .038 - .040 and run flawless from 600 RPM to 6000 RPM. I sometimes run 4lbs of pulley with one program,
at other times my more aggresive program, sometime I run 6 lbs with one program, at other times my more aggressive program, Take those 4 combinations and double them because I've run all 4 set ups with and without Nitrous.
SO FOR ME, Denso is clearly the best plugs out there, but for you it may not be.
As for Spark blow out, NO PROB with a Multi Spark Ignition,
they fire correctly up to 1.00 Gap
Third Summer on the same set of plugs, so obviously the Denso's (and my large Gap) work well for me, even with all the Nitrous I throw at it.
don't like them.
and so on......
#58
don't like them.
and so on......
don't like them.
and so on......
Rob,
Aren't you also running a Plasma Booster. Does that also have an effect on how the plugs perform?
#59
i was also told that TR6's are one heat range cooler
and to gap them 35,000 also with my current set up
4# lower, 2.80 upper w/ anderson power pipe and Pro M 80
seeing about 14-15 on the autometer
safe tune 404/505 on the mustng dynometer
4k miles on them with no problem exept cold starts give a rough idle at first and then warms up and runs great (could be chip, could be plug?) dont know
although i might try the I-22's next round but ouch $
JDM said i could run the same TR6's (gapped 35K) w/the Magnum w/ no problem at all
hope so, cause im gettin ready to find out real soon
