Hellwig rear anti-sway mounts backwards?
Old 05-15-2004 | 01:59 AM
Suavy's Avatar
Puff, puff give then! Amigo!
Old 05-15-2004 | 02:03 AM
Tim Skelton's Avatar
Old 05-15-2004 | 02:04 AM
MEAT BAG's Avatar
Originally posted by Tim Skelton
The attractive part of this option is that the center section is no longer fighting the diff cover and panhard mount for space. As it is now, I cannot drop the ends of the bar because it strikes the diff cover. On the other side of the diff, there would not be a big protruding diff cover to hit.
Hell, I may see if the Hotchkis will flip.
But, according to my calculations, the Hellwig bar is WAY stiffer than the Hotchkis, so I may switch anyway.
(stiffness = dia(mm)^4)
stock -- 0.9" solid -- 273091
Hotchkis -- 1.0" 1.0" hollow -- 416234 = 53% stiffer
Hellwig -- 1.13" solid -- 666727 = 144% stiffer
Plus, since the Hotchkis is hollow, that number is actually too high.
The front Hellwig and Hotchkis appear pretty close.
I thought that the Hotchkis was stiffer?
Old 05-15-2004 | 02:06 AM
Suavy's Avatar
Tim, how did you get my baby picture?
Old 05-15-2004 | 05:22 AM
Bad as L's Avatar
Tim
If you decide to replace the rear Hotchkis bar, I'd be interested in buying it.....Let me know
Dale
Old 05-15-2004 | 09:25 AM
Originally posted by Bad as L
. . . If you decide to replace the rear Hotchkis bar, I'd be interested in buying it.....
We will be talking, then, cuz I'm definitely giving the Hellwig a try. Great. Another weekend of welding, cutting, painting, and wrenching.
Old 05-15-2004 | 10:11 AM
ShadowBolt's Avatar
I have the Hellwig bars and they will keep the truck flat as hell in the twisties. I worked with Hellwig on the L set-up. I bought the bars and then they would not bolt up on my L. After talking to them they said they needed an L to see what the problem was. I posted on here and NLOC and had them an L in two hours. They then sent me new brackets and made sure I was happy. Great customer service. The Hellwig bar is also made from heat treated 41 40 chrome molly. Here is the contact info if you need it. David is a great guy and will help you all he can.
Jerry
David Wheeler
R&D Manager
Hellwig Products Inc.
559-734-7451 Phone
559-734-7460 Fax
Old 05-16-2004 | 03:33 PM
droptail's Avatar
Hellwig rear u-bolt position
This is the orientation that worked for me, slightly upward. Have good success with this setup on open track events.
Old 05-16-2004 | 07:40 PM
Re: Hellwig rear u-bolt position
NICE!
Where did you get the panhard parts? Did you do the fabriction yourself?
Old 05-17-2004 | 12:22 AM
droptail's Avatar
Got it from a cohort who wasn't going to use it, had it for a few years I think ( he has a Mustang and AMX), but it was mostly custom fab and welding, you know, tubing, rod ends, brackets. Wish there was something (long) like this on the market for us. I can't afford any lateral motion with my tight wheels /tires combo. If I can help with any specifics, please ask. There again note my u-bolts are nearly horizontal, which I spent alot of time adjusting, although I have a few obstacles under there not found on a stock truck.
Old 05-17-2004 | 12:33 AM
LatemodelRacer2's Avatar
Originally posted by Don's Bolt
Looks like you might have to go to a Nascar style sway bar
http://www.1speedway.com/Swaybars.htm
And they are close you you, just outside of LA
I can get you these bars for a great price. We run this style on my latemodel and it works great and you could change the bars real quick to adjust to what you want.
Old 05-17-2004 | 12:42 AM
. . . but it was mostly custom fab and welding, you know, tubing, rod ends, brackets. . . . If I can help with any specifics, please ask. . . ..
Where can I find some better photos?
A picture is worth 1,000 words! Thanks
Old 05-17-2004 | 12:44 AM
But how in the world would I mount them? I seems to be that these are using a true torsion bar effect. That would mean a rigid side-to-side mount spanning the frame rails and downlinks/attachments to the axle, right?
Old 05-17-2004 | 02:12 AM
Red Chief's Avatar
Custom Fabricated Swaybars
Tim, I was just reading my "Grassroots Motorsports" Mag and saw an advertisement for "custom sway bars built to your specs or ours for approximately $150". The company is Saner and the phone number is 772-873-9227 or web site: www.sanerperffab.com. I have never dealt with this company nor am I affiliated with them. Just passing on another option. I was thinking of calling them to do a bar that would have a higher hump to clear the cover.
Old 05-17-2004 | 09:35 AM
YEs it mounts rigid but the preload is adjustable. It will have dowlinks that atach to the axle. Each side is mounted by a threaded bolt with a eye on the end for the bar to go through. This way you can adjust the height of the sway bar and stil be able to keep t he bar neutral at a higher or lower height to start off with which would be good in you case. If you want i can take some pics of the sway bar setup on my race car.
Quick Reply: Hellwig rear anti-sway mounts backwards?
