I got NOS, but can I use it
i have a NOS KIT ( DRY) 50-125 shot for my L which came with the truck but the previous owner removed it after he shucked 7 gees for new ford block installed after slinging a rod.
The point is that i still have the kit laying around the house but i think i cant use it on the stock block considering im already in the 400/500 club (15 lbs boost) and what had happened to the previvous owner
does anyone have advice on what i should do with the kit or converting it to a WET shot and more tuning?
or sell the kit (after all i heard DRY is dangerous) and save up this summer for forged block and more boost?
either of the last two would work. a wet shot with some tuning would mean fun now, but if you can afford it a forged bottom end is the way to go, but you would probably have to buy a new wet shot kit after that i would get a built engine and trun up the boost if you can afford it. otherwise i have heard you really can't go over a 75 wet shot. at 15 lbs of boost you would probably have to spray even less.
Re: I got NOS, but can I use it
edit: I would just get the solenoids and other parts to convert it to a wet kit......
Originally posted by Rob_02Lightning
As said, Wet ONLY for the L, as also said a 50 shot with a safe tune should be just fine, any more and your pushing your luck.
Now thats funny coming from you
8aSS
First, change your screen name
Second, either convert the dry to a wet (If possible) or sell it and buy a wet kit if your set on nitrous
