DTC P1406 - Where is it?
Nevermind, I found it.
Its waaaay to hot to work with at the moment (was driiving before).
The hose looks fine (not disconnected), but it may be clogged or the sensor might be bad.
Second question:
Does a malfunctioning DPE EGR sensor effect drivability? (aka, how soon should I shop it for it).
Second question:
P1406
I'm getting the same reading - P1406, Differential Pressure Feedback Sensor Downstream Hose Off Or Plugged. My Ford is driving fine, but I noticed that all of a sudden it is smoking out the tailpipe (yikes!) so I put the tester on it. Unfortunately I don't know where the sensor or the hose is. Sometimes I think I do well just to locate the engine. :-) Any help would be greatly appreciated.
