JL Does it again... 10.25@133.45
#47
#48
rscoleman
quote:
Originally posted by Duende
JL uses 52" traction bars, right? He gets some sick 60' times, with shorter bars... Is there anything special about those traction bars over the 58" offered by everyone else, besides the shorter length? Or is it in the shocks and weight of his truck?
Just don't understand those freaking impressive 60' times, and why his bars are a few inches shorter then the others...
Long bars (long/low intersect points) create traction for the longest time but react slowly and are lazy off the starting line. Short bars (short/high intersect points) created traction for a shorter time but react much faster and launch harder than long bars.
rscolman: I must say hats off to you for hitting it on the head.. Yes your right. thats why i designed our bars differently, because i knew thru MUCH testing! the design of our JLP bars were the *perfect* length!..Thats why you'll see the trucks making enough power with our bars will lay down 1.4 60fts. I firmly believe my truck with a well prepped track will produce 1.3 60fts! using our Bars..We might give it a try @ MapleGrove this comming NMRA event. The track will be prepped for sure!
JL
JL
