MSD's Engine Knock Alert
I had an MSD unit on Myphoon. It will definitely retard the timing when it hears detonation. However, the problem I had with mine and maybe (hopefully) MSD has eliminated it, was that on sensing detonation, it would pull a bunch of timing and the truck fell on it's face then after the detonation stopped it would take two to three seconds to restore.
Sounds like this might not be an issue with the J & S unit, but do they have one to work with our COP setup? Their writeup specifically mentions "single coil".
Originally posted by danoid5631
A bad tank of gas will show more than at WOT. I am not stupid or new to this.
Unless it is setup to pull timing while the knocking is going on it is useless just like Dale said.
Originally posted by danoid5631 Trust me I know when my baby isnt acting right. If you want gaurentees before you mod your truck I wouldnt mod it ever. Hell detonation isnt the only thing to blow these motors once modded.
AND I gaurantee you that Detonation is the single leading cause of engine failure in modded Lightnings.
I'm not happy in the dark, therefore I seek the light......not as it shines threw the new window in my block tho.
Just got off the phone with John over at J&S. At the moment they do not have a system that will work with our trucks, but he mentioned several different approaches which they are investigating now. He said he would send me an e-mail with an update in a month or so, and if that happens I'll post the message here.
on
1 Post
Originally posted by Bad as L
This thread is not about knock sensors its about knock detection and warning the driver. And I don't think it has been covered.
(2) is not the problem; (1) is.
