GTP vs L: Knock Sensor
The Eaton supercharged Pontiac Grand Prix uses knock sensors, and the Lightning cannot. I wonder why the k/s works on the GTP and not our trucks. Could it be the location of the Pontiac's k/s?
Seems to me a functional knock sensor on the Lightning would save alot of engines.
Re: GTP vs L: Knock Sensor
No disrespect ot the car, it kicks *** in its class, but its nearly half the torque and a good 200 hp off. I'm guessing this has quite a bit to do with it.
Also engine construction as well. Almost all n/a ford truck engines i've driven have had a real slight knock to it at idle, i don't know if that honestly makes a difference, but surely you can imagine knock sensors working well for one engine type and not another.
knock sensor
It's the location of the knock sensor in our trucks that is the problem. It is mounted in the engine valley right under the intake this works good on a N/A engine but when they put the deeper intake and the S/C on the sensor picked up the blower noise and retarded the timing. so they reprogramed the PCM not to look at the knock sensor data
Re: Re: Re: GTP vs L: Knock Sensor
My friends modded (bolt-ons) GTP runs in the 12's. But, he does have spark retard problems.
