Scan tool w/ data logging
I'm looking for a good scan tool to be able to pull and erase codes, but also have the ability to datalog. I've been thru several pages of info and products, but there are so many with a wide range of pricing. I thought I'd see if anybody on here knew of a good product.
Thanks Mike
Thanks Mike
SCT is supposed to be coming out with their datalogger tool this month last I heard. Here's some info on it from the forums over on modular depot:
The Raptor Datalogger consists of a High Speed Data Acquisition unit and a Windows Ap.
That being said it will datalog 5 analog ports and whatever you can command the EEC to send you. Usually PIDs, DMR's and any other Ford specific requests can be used in full duplex mode.
Yes it can reset DTC's.
The Raptor Datalogger consists of the HIgh Speed Data Acquisition Unit and a Windows Ap which needs a Laptop PC, Pocket PC or a Smart Display Unit (aka Info Panel ). It is not a single unit that connects to the OBDII port only as it needs another 'box'.
"100 samples/sec for 5 analog and 15 PIDs or DMRs simultaneously for a total of 2000 samples/sec"
-Nate
-Nate
Here's where the info on the SCT datalogger is:
http://forums.modulardepot.com/showt...threadid=25267
-nate
-nate
So, is this gona be like the predator system or is this a totally independent datalogging system? I would like to have SCT's new handheld tuner to have a datalogging capability or have this laptop datalogging program also load tuning programs. Cause the predator does scanning, datalogging, codes, and program for around $400 and to have the same set up with SCT you would have to get the handheld and this laptop program for around $800. I would get the predator but I like my SCT programs.
