Blower belt slip problem fix?
Old 06-12-2004 | 09:54 PM
l-menace's Avatar
not mentioning any names, but a friend who uses a 16# lower pulley has recently experienced IMMENSE belt slippage.
how did he cure it?
replaced the Belt Tensioner Spring.
I look at it like this:
the tensioner is designed to be used with a stock DIameter Lower pulley. Well we all add larger pullies, therefore the tensioner pulley is moved CLOSER to the center of the engine putting MORE stress on the tensioner spring than stock.
after a prolonged time, I'd say the stock spring would wear out.
Before he replaced his spring he could squeeze the belts together (just under the blower pulley where they are close) with very little effort. Now with the new spring, it doesn't budge.
I don't like to re-invent the wheel, I just like it to work as designed.
replace the spring and then report back is my recomendation
  #32
Old 06-12-2004 | 09:59 PM
jimkalfakis's Avatar
Your right MENACE, not only do we add a larger pulley that adds stress to the tensioner but, we also add a smaller and tighter belt.
  #33
Old 06-12-2004 | 10:03 PM
Originally posted by Tim Skelton
Apparently not as addled as yours.
ha ha ha
  #34
Old 06-12-2004 | 10:04 PM
Tim Skelton's Avatar
Keep the tech coming. This one is turning out to be one for the archives.
  #35
Old 06-12-2004 | 10:12 PM
l-menace's Avatar
sarcasm from Tim? Nah...
  #36
Old 06-13-2004 | 05:39 AM
No, I'm serious. I'm interested in hearing more about the art and science of belt traction.
  #37
Old 06-13-2004 | 10:27 AM
Casey02L's Avatar
I've heard that using a richard racing pulley and a gatorback is belt sucide. I have heard of the pullies chewing up gatorback belts very quickly. Anyone else?
Quick Reply: Blower belt slip problem fix?
