trouble codes
To take a wild *** guess at the lean codes it would be dur eto the Granatelli mass air - It is likely not calibrated to match your truck.
The Egr flow problem is likely something else - Try searching here for that - I bet there are 100 threads to pick from with the same issue...
Good Luck
Doug
Good Luck
Doug
