Making the engine bay hoses Black again???
Old 06-16-2004 | 09:05 AM
fractaldragon's Avatar
Used foamy engine brite to clean the engine the other day, but it turned my hoses white! I am putting the truck in a show this weekend. What do you guys use to make the parts black again???
Old 06-16-2004 | 11:29 AM
topsy's Avatar
I've used Meguiars gold class trim detailer on plastic and vinyl and it's good stuff, so I'd give it a try.
Old 06-16-2004 | 11:32 AM
MaxPower's Avatar
I think Meguiar's also has a "Back to Black" product. I've used it on the hoses - works well.
Old 06-16-2004 | 11:41 AM
93Cobra's Avatar
Spray it down with tire dressing, and then let the truck warm up with the hood closed. While it is hot, spray hoses again, and they will always stay shiny. You will be able to wipe them down occasionally if they have any dust or grime on them... and still have a shiny finish underneath.
Old 06-16-2004 | 11:43 AM
KIRST8404's Avatar
Dont use any tire dressing- it will attract dust and will make it a mess to clean up next time. use a little WD40 on a rag and wipe it down. then just rinse off. works good.
Old 06-16-2004 | 11:49 AM
Silver_2000's Avatar
Wouldnt WD40 also attrack dust and dirt ? And potentially weaken the hose as well ??
Old 06-16-2004 | 11:51 AM
KIRST8404's Avatar
WD40 will attract dust too, but thats why i said to rinse it off when your done. He's tring to remove a white substance that was left over from the degreaser. The WD40 will not harm the hose's.
Old 06-16-2004 | 02:37 PM
illegalspeeds's Avatar
I use a product called CD-2 Engine Detailer that they sell at Auto Zone. It gives everything in the engine compartment a "candy-coated" look, and it doesn't attract too much dust.
Old 06-16-2004 | 02:52 PM
93Cobra's Avatar
If done improperly (just sprayed on), then yes, it will attract dust. This is why you have to warm up the engine after spraying, and then spray again. This will soak the stuff into the rubber of the hoses, and keep a long lasting shiny finish that just needes wiped down occasionally.
This is the shine I am speaking of:
Old 06-16-2004 | 04:17 PM
DEIMATT's Avatar
I thought the old stand by was, Half Simple Green/Half water, spray the whole motor down with it, Let soak
Spray off and try not to douse the CP's and then wipe down?
Old 06-16-2004 | 05:58 PM
Eds 01 Lightnin's Avatar
I use the "wipes"...they make the hoses shine and it lasts a long time!
Old 06-16-2004 | 06:49 PM
Odin's Wrath's Avatar
Black Magic
Old 06-16-2004 | 06:59 PM
EZGZ's Avatar
Just used simple green on mine this weekend. It turned the hoses white.
I use "303" and wiped down for that brand new look
Old 06-16-2004 | 08:21 PM
01 XLT Sport's Avatar
That what I just used under the hood. It wasn't really dirty to begin with but it looks DAMN GOOD now...
Old 06-16-2004 | 09:02 PM
EZGZ's Avatar
YO Fractledragon
Don't forget to clean the bottom side of that hood.
I used the rag with the excess "303" on it and it looked pretty good considering it isn't clear coated.
I tried waxing ounce but it is to grainy and hard to get off. Never do that again.
http://www.303products.com/main.php?infopage=home
Turn up the volume for a nice intro
Quick Reply: Making the engine bay hoses Black again???
