Modding, nitrous, A/F...
Hey all,
Just found out a couple days ago that no dyno here in Hawaii monitors A/F while dynoing vehicles... So with my new mods on the way - mainly a 4lb pulley, and a nitrous kit waiting to be installed... Do I have any options here?
I want to run a safe tune, but without a way to check that the tune I get in the mail is safe...maybe I shouldn't even put the mods on. I don't want the way I check to see if I've got a safe tune to be making a pass at the drag strip.
"Well, I made it...must be good."
Do I have any options here, or am I SOL on modding until I get back to the mainland?
Thanks.
Thomas
Thanks.
Thomas
Your Tune
If I were you, I'd install the Nitrous Oxide instead of the 4 lb pulley. Most Nitrous Oxide systems are designed specifically for your stock application that will not hurt your air/fuel. If you install the Nitrous, 4lb pulley and other mods, this will change your air/fuel. Just my opinion from using Nitrous on my stock Lightning before any mods. I use NX Nitrous system.
Re: Your Tune
Most (if not all) Nitrous Systems throw a ton of fuel at the motor, you have no problem there as Black Beast said. As for the 4lb'r, not such a big prob either, the main thing is TO NOT get a race program. If you use a good tuner and tell them it has to be tuned for regular street octane, keep the timing 16 degrees or under, and a rich A/F, you'd be fine and as safe as you can hope for with those Mods.
