AGSF-12C vs. AWSF
AGSF-12C vs. AWSF
Just got back from the Dyno and made 384 RWHP and 494 RWTQ (SAE) with an A/F ratio of 12. Guess I had expected a bit more , but my tuner said it was due to my plugs and gap.
Currently I'm running NGK TR6@.048. He told me to get some Motorcraft AGSF-12C@0.35 and I would get close to the 400/500.
So I searched the forum and found some info that the AGSF is for the post November 2002 heads with 8 threads, and the AWSF is for the 4 threads heads. Is that correct or can I use either one for my 4 threads head?
Some info I found on another thread...
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
Those numbers are not very good porsen...
It would be unfair to disclose the name of my (local) tuner as he's only had one shot at it so far. He told me to get a new air intake as the current was a bottleneck with it's 80mm neck. I'll work with him a little more since I got unlimited reburns from him
Originally posted by porsen
That's what I thought. What should it be?
On a side note...my personal opinion is...you got too much pulley! At least get a good aftermarket heat exchanger to help keep that sucker cool!
I know, I know, I'm pushing the envelope when using the L as a daily driver, but once on a #8 there's no turning back (until I blow a plug)
JeffsLightning, what numbers would you have estimated from the mods?
