My dyno with the stock block and KB
I have a stock block and an efan, psp cold air, tr-6's and 15.5#'s on the KB. It was way hot in the dyno bay. Iat1 was reading 113 and iat2 got up to about 145 after the 3rd pull. Since dyno clock was running couldnt afford to sit there and let it cool down.
Your stock 42lb injectors can handle more fuel with 255pumps. We maxed mine out at 496/562 on a safe tune. 12.1 a/f, 14 degrees timing, 5200 shift point all on 93 octane. I am pushing 16lbs boost, but I have dynatech longtubes and highflow cats.
Your tune is everything, did he give you a dyno sheet demonstrating RPM's rather than speed? And why the variations in a/f (maybe because it is based on speed?). The only reason I ask is my a/f levels and follows a smooth line once I am out of the gate.
Great power, congrats!
D-Day
D-Day
Did I miss something? I can't see any dyno sheet...I'm very interested because I just got my new KB and am in process of installing the dynatech longtubes and high flow cats along with all the other goodies...heh heh heh. All on a stock block. I have the trans out right now installing a PI 2800RPM converter before I do the FTVB and 4x4 pan change. What kind of HP/T number should I see? Thanks for all the great info here guys!
We just printed that sheet out real quick at the end and meant to show rpm instead. He couldn't get that dip out in the air/fuel and said he was going to talk to someone at sct.
wmj shoot me an email www.slctk@verizon.net with your # and I'll give you a call since your local maybe I'll come by and check you out. I take it you won't be ready by fun ford.
Re: My dyno with the stock block and KB
Originally posted by 2bscrewed
. . . Since dyno clock was running couldnt afford to sit there and let it cool down. . .
Looks like a smart, conservative setup you have. I will be gunning for something very similar.
