Is it worth it to just replace the rods?
I asked on nloc, but wanted too here also.
I was just wondering because I have the KB now, and it sure would be nice to run 18-20#'s with it. I know as soon as I did I would definately put a window in my block. I just wanted to see how many people have done it, and a ballpark cost. Still haven't decided if I would do it myself or take it to a shop. It has to be considerably cheaper than a whole new block, but I wasn't sure how much more power it could handle.
Any opinions are appreciated.
Shane
Shane
I get this question alot. I feel that its more benificial to rebuild the whole bottom end then to just fix the "weak point." The rods from the factory arnt the greatest so replacing them is the way to go. Spending the amount of money that you will replacing the rods you are better off with the whole bottom done. If you fix the weakpoint then theres more than likely going to be another (pistons, rings, etc..). We carry full bottom end kits and have them in stock today.
My final answer would have to be rebuild the whole bottom end and run as much boost as you can through that sucker.
JimIII
JimIII
agreed
there's so much more than just replacing the rods. If you are gonna go through all that, do it right. Just replacing the rods doesnt' mean your golden. Depending on the rod......they are rated for x amount of horsepower.
If it were me, I agree with Jim, do the whole bottom end. Don't forget , your probably talking a 50/50 failure rate on these engines of rods/lower end.......and valve train/head problems. If you run lean and burn up a valve which toasts you piston........isn't anything a built lower end is going to prevent.
Re: agreed
Originally posted by EZGZ
Connecting rods don't just jump off the crankshaft because your making lots of power.
It is detonation and high RPM that will cause failure.
I agree that it is a safe tune that keep the engines alive and well.
