- VSS Sensor Location? -
Originally posted by BigFan
Do you want the color of the wires as they come out of the transmission or as they go into the computer ?
But i guess there is no difference splicing right before the computer? Thisway i figure everything will be inside the truck once installed, not half way under the truck...
Originally posted by Factory_Tech
A GEn2 doesn't have a VSS, it reads off of the OSS (output speed sensor) which is on top of the extension housing on the transmission. The old VSS was in the rear end. Many people and manuals use the terms interchangably.
G
G
Hopefully rhino ramps will be enough to get under truck with tomorrow for this..
TTT
Only thing i found was driver side, almost top of trans, small plug with 2 wires... is this it? [yellow/green & orange/black]
There is also a small wire harness coming out of the rear end, but cant see how many or what color the wires are..
looks like the rear, almost dead center of trans (between the O2 sensors) is the wire the instructions are asking for (dark blue/yellow stripe) BUT its not the location they are telling me...
They say front of trans, driver side, top is the VSS... but the colors dont match.
Anyway, ANT thanks for the help, i think shaun was right on the OSS, as those wire colors match the instructions.
