Post Apten/4lb #'s
Post Apten/4lb #'s
I dynoed the Lightning today. This was the first time after my Apten and 4 lb lower upgrades.
I used the same tune for before and after #'s. However, the weather was hotter and more humid here today in Missouri.
Pre Apten/4lb #'s 350rwhp/424rwtq
Post Apten/4lb #'s 410rwhp/487rwtq
Now I just need a more agressive tune.
Originally posted by BigFan
Nice numbers with the apten and 4lber, The Pre numbers were very low considering you had a chip and a electric fan. My truck Dyno'd 357RWHP bone stock on a 95 Texas Day and only a K&N.
Nice #'s! Should be a wee bit higher though. A good tune tweaking will help ya out.
I wanted to dyno my truck with the same tune pre/post porting/pulley, just to see the actual gains I got from those mods.
The tune I am running is just a basic JDM J39, nothing special.
Also, dyno #'s can vary from one dyno to another, that's why I used the same dyno and dyno operator. I might have picked up a few more hp if I would have dynoed in October, like the base runs.
Yeah, a/f is fine, maybe a bit more timing is all I need.
Also, I use an LM-1 wide band o2 sensor, placed in the rear o2 bung. It consistantly registers 1/2 point richer in a/f, and I'm sure pre cats it would register even richer. So, I would think 12.2 at the tail pipes would be safe.
Maybe you got a strong truck or maybe your dyno plays with "fuzzy math"?
-Mark
