Cold air kit ?'s
Cold air kit ?'s
I am looking for any kind of numbers wether there track or dyno numbers.
What kind of difference have you guys felt when going from a stock air box to a cold air kit. How much e.t. was gained or H/P was gain just from that mod.
Has anyome use this kit before. Yea or a Nah on it
I was just Lent a C & L 85MM mass air meter to see if I like it. They say on C&L that you gain. The 85mm Lightning MAF system has increased performance by as much as 33 more rear wheel horsepower in independent testing on a Dynojet dynamometer.
The increase in horsepower is coming from both the increase in total airflow through the package as well as from a resultant boost increase of up to 2 additional PSI. Due to this increase, the air/fuel ratio of the stock vehicle is adjusted by one point from 11:1 to a more aggressive 12:1.
Thanks Jason
Thanks Jason
http://www.johnnylightningperf.com/s...products_id=32
The sound alone was worth it!!!
I think they are stretching it on the 85MM
Generally lean is not a good thing. Better be running good fuel that's for sure.
