Poor man's susp. drop and sway bars?
I was thinking about putting on a set of FRPP front springs I have and a set of JLP 4" drop shackles to get me close to my 1/3 drop I'm wanting.
1.)Now I have a '03 still with stock shocks. Should I change those out since I'll be dropping the rear 4" over stock? (I have '01 springs and looking at 4" shackles for a total of 4" drop vs. '03)
2.)Also will it be beneficial to get aftermarket swaybars to try and clean up the "slop" created by the longer shackles...or should I just get shorter end links and keep the stockers?
I'm looking for something that handles when I decide to put it through the paces when I get the urge, but still drivable on a daily bases. TIA
3.)One last question...any feedback on the new "softer" 2/3 hotchkis kit for Lightnings?
on
1 Post
Re: Poor man's susp. drop and sway bars?
Originally posted by ~nightcrawler~
. . .1.)Now I have a '03 still with stock shocks. Should I change those out since I'll be dropping the rear 4" over stock?
2.)Also will it be beneficial to get aftermarket swaybars to try and clean up the "slop" created by the longer shackles...or should I just get shorter end links and keep the stockers? . . .
3.)One last question...any feedback on the new "softer" 2/3 hotchkis kit for Lightnings? [/B]
With all due respect, I do not concur with Lightningguy's recommendations. Coil cutting might be okay, but pulling a leaf will hurt, not help, the handling.
Just any old shock will not do for a heavy, stiffly sprung truck. They will probably not perform well from the get-go and fail quickly. From most reports that I have seen, most of the "drop shocks" (with the possible exception of Doetsch Tech) are junk -- valved and sized okay, but not well constructed. The most cost-effective option seems to be the specially valved Bilsteins from Hothckis or Roush.
Originally posted by AmoJohnny
I have the new hotchkis TVS kit sitting in my house, planning to put it on next week. I will let you know how that goes. Soon as that is done, I plan on putting my order in for the hotchkis/bilstein shocks...should be fun.
Ya I agree with you too Tim about the modifying stock springs and cheap shocks. I was wanting a drop on a budget, not trying to cut corners though. Thanks for the schooling on the sway bar. I've heard the panhard bar deteriorates ride quality some...Is this true? Also would it hurt a truck on the dragstrip? Thanks again
on
1 Post
. . . I've heard the panhard bar deteriorates ride quality some...Is this true? . . .
Tim,
I used to work on mini-trucks and we used to do that setup all the time. Another way to go lower is to use a flipkit and that'll net you a good 5 to 6 inches!
I've also had luck with just throwing a couple of bags of cement or sand in the bed to level off my truck some. When I first did my truck, I cut the front coils a little too much and had a rake that I didn't like. After about 250 to 300 lbs. of cement in the back, it pretty much leveled the rear out.
Just providing some input on lowering...
on
1 Post
Originally posted by LightningGuy
. . . Just providing some input on lowering...
Pulling leafs and adding cement (gulp) don't really seem to be consistent with that goal.
Originally posted by whiplash
For those of you that have done this cutting of the front coils....how much did you cut off and how much did it lower it?
Just don't wanna cut off too much
Tim,
My truck still handles better than most trucks I have dealt with! I fabbed up some brackets to hold the bags of cement in the rear. Also, I think I can achieve near 50/50 weight distribution by adding more sand or cement in the bed!
Also, what do you think about using a couple of shower curtain rods as braces for the bed of the truck? Would they stiffen it any?
Originally posted by Tim Skelton
Your suggestions will lower alright, but you may have missed ~nightcrawler~'s statement that "I'm looking for something that handles when I decide to put it through the paces when I get the urge."
Thanks for the input, but just not something I'm willing to do with this truck.
The only downside is potentially some noise from the heim joints. The Ruslow design has also been criticized for being too short, causing excessive lateral movement as the axle moves up and down. But since it's the only game in town, we live with it.
You Cheap bastards...
It costs $125 bucks for a set of Springs from Ruslow which can be had anywhere from stock to 1500lbs. Order a set and do it the right way.
They will drop your truck about 1 1/2 or so in the Front.
Cutting Coils is the hack backwards way to do it. You own a 30 Thousand Dollar truck, Im sure you can afford $125 bucks to do it the right way.
When I put my panhard bar on I didn't notice and change in Ride or any noise. What do make noise are the So Cal swaybar links. I have to spray them down every few weeks or so to keep them quiet.
