Stock computer AF wrong?
Some friends recently helped me out with a plug change. When we removed the plugs they were in bad shape... a few of them were really crusty looking but all pointed to the truck running very lean. My question is...how the hell is this possible with a stock tune?
These were the stock plugs at 50k miles... I had a chip that I ran until about 25-30k miles ago. Im only running a 2 LB lower .... and I have been back on the stock tune for over 25k miles now. Any ideas?
Steve: Nah, if it was a 85 or 90 then yeah, but 80 is stock anyway
min150: Yeah, Id say its been on there for about 10k miles now....or around there. I have been told the stock computer can adjust for it, I would think I would throw some sort of SES code if the A/F was out of stock range.
Let me see if I can find the dyno chart and post the link of what I was talking about. This guy never had a code thrown. I'm not sure but I think it won't throw a code until it is way too lean. I mean in closed loop the truck is setup to run fairly lean for emission purposes.
I have a calibrated a/f meter and I can only read it when I'm in open loop. In closed loop it is a lot leaner and not on the visible range.
Also the stock computer can only adjust so much when you're in open loop. Which is basically as soon as you are not cruising or idling. It is limited to what is in your tables and depending on the air conditions where you live it may not be enough for a 2lbs lower.
edit: Well can't find the one I had in mind, but here is another one with stock computer and 2lbs lower. This one is in Houston where the weather is often hot and humid so poor air quality for the lightning. http://www.svt-enthusiast.com/albums/RUNVS/Rsi_dyno.jpg
I would drop the fuel filter and change it just to be sure (cheap insurance)
But what somebody's else's truck should not and will not have any bearing on your truck. Every truck respnds differently to the same mods, so something to that effect
Good Luck in finding the problem and correcting it. Because I know the feeling of worring about the truck with a new/old house.
