Is it possible to test a MAF SEnsor?
I know this may sound weird, but I would think you could take a voltage reading and use a hair blower/dryer and aim it at it and see if the voltage changes? I mean it senses Air Flow right, so a hair blower will put out some decent air flow…
Just an idea…
It may measure the resistance change, if so then you would have to take a resistance measurment rather then voltage.
Should have added if you try the hair blower method I would set it on the cool setting, don't know if heat would harm it or not.
Just an idea…
i don't think heat would harm it but it would give some odd readings i think. The maf functions on the cooling effect of air removing heat from one wire as best I kno. vac cleaner might work a lil better. But still don't know how you would really test it.
Best method i think would be to swap it with a buddies to see if it fixes whatever problem your apparently having.
