Am I stoopid or what? HELP !!!
The trick is to strike the arm 90% to the castle nut side.
By that I mean hand tighten the castle nut to protect the threads
(even though you don't want these)
Now hit the femaile side that has the Morse taper like hitting the top of this T the taper being horizontal and the tie rod or whatever being Vertical.
It slightly deforms the female tapered side enough to release it. When you put it together with the new Male peace it will get its shape back from tightening the nut.
The pitmin arm device sounds good or I just use a small craftsman gear puller.
It usually pops when it comes apart.
with a 5 LBer ... It stayed stuck ... Next time I go with
the puller (IF THERE IS A NEXT TIME!!!!)
