Lower intake torque and sequence
Hey guys,
I did a search and got all the torque and sequence info i need for installing the intercooler adapter plate and supercharger (magnum powers baby!) but i am also changing from my 2000 lower intake and intercooler to a 2002 setup. With that being said All i need to know is the torque specs and torque sequence for attaching the lower intake to the heads. I was also wondering if the lower intake gasket is reusable. I would guess not but just thought i would ask. Thanks to you all. One more thing, does anyone know if the bolts for the lower intake are torque to yield?
Install the intake manifold & thermostat outlet.
Install the bolts. Tighten the bolts in two stages in the sequence shown.
Stage 1: Tighten to 2 Nm (18 lb-in).
Stage 2: Tighten to 25 Nm (18 lb-ft).
I have heard of people reusing the intake gaskets, but I personally wouldn't recommend doing so. and the bolts are not torque to yield, so do feel free to reuse them.
hope this helps.
good luck.
later,
chris
hope this helps.
good luck.
later,
chris
