Caster/Camber plates
Hey Ryan, I just dropped you an e-mail, but for anyone else.
the answers can be found here:
Cam Bolt Thread
Napa kit courtesy of Vinnie:
Ford kit (both parts) courtesy of jmlay:
I assume that these part numbers are accurate. I'd recommend the Ford kit because as you can see it looks to be substantially stronger, although it is more expensive.
your local dealer will be able to verify the part numbers.
good luck.
later,
chris
Cam Bolt Thread
good luck.
later,
chris
I'll second Chris's recommendation about the Ford parts.
My son's truck (not an L, but a '97 F-150) got a 3-1/2" Fabtech lift and while setting the alignment, the D shaped hole in one of the washers stripped out and the the bolt turned freely. This was the non-Ford part.
When replaced with the Ford version...Zero problems.
Good Luck,
Herb
Good Luck,
Herb
