air intake e-fan?
air intake e-fan?
Well i'm bored, and i started thinking about the L and ways to make more power. I sat there lookin at my filter setup and then started thinking about fans... what if you positioned a small e-fan near the filter with a simple switch in the cab? anyone ever done this? am i the first one to think of this? or is this a stupid idea? would it be possible for this setup to push more air through? what do you guys think?
I tried doing that a while ago. After I added my open air element I noticed a sluggishness when it was hot out. I have a 4" bilge fan hooked up to some dryer ducting and routed it near my filter. I forgot how much CFM the fan is good for.. maybe around 320. Anyways I have it switched. I did notice that the ducting of fresh air up to the filter helped, but it didn't matter if I had the fan on or off.
https://www.f150online.com/galleries...6572&anum=2739
I would just get a fast air, get a cleaner look and forget adding a fan.
Nope...
Basically what others have said.
You just can't get a fan big enough to move the volume of air we need.
In essense, a roots style blows is a big air fan/air pump, so you would need something at least as powerful as our blower.
Compressed air is an option (and you could ALMOST do it) but the added weight isn't worth it.
Coldie
Coldie
