Fog Light Quit Working
Figured I would post this in the L forum too:
I have a '99-'00 Lightning front bumper cover on my SCrew. Recently the passenger side fog light quit working. Tested the voltage coming to the light - 11.94. Bulb is OK. Switched the fog lights and both work on the driver's side, but neither work on the passenger side. What could be happening here??
Thanks in advance!!
Thanks in advance!!
Just curious
When you say you tested the voltage coming to the light, are you meaning that you tested at the passenger socket (with switch on)?
If that's the case, (you have 12v at the socket), and the bulb works; it has to be something in the bulb/socket connection. Perhaps a bent contact or some insulator stuck in there?
I have the 99-00 fogs, so they use an H-3 bulb (bulb with pigtail), so it really does not have a "socket". I disconnected the fog light housing (including bulb) and turned on the switch. I took the voltmeter leads and touched them to the positive and negative wires coming from the truck and get the 11.94 voltage. That made me think it was the fog light housing, but I took that housing and installed it on the driver's side and it works fine. Took the driver's side housing and hooked it up to the passsenger side wires and NOTHING.
I am usually pretty good with electrical things, but I am stumped on this one.
