Engine Removal
Old 09-10-2004 | 07:13 PM
SVT_KY's Avatar
Engine Removal
The neverending QUEST ...
EDITS
October 2004
Added Steering stuff
Added Rear Suspension Torque Specs
Added Water Pump
Added Cooling Fan Removal
Changed to Click Overs
September 2004
Added Remove Wheel bearing
Added Rear Brake Section
Added Panhard Bar
Added SC stuff
Added Cooling Systems
Engine Section
Remove Engine
Remove Intake Manifold
Remove AC Core
Remove Water Pump
Cooling Fan Removal
Supercharger Section
Inspect Supercharger Coolant
Drain, Fill and Bleeding Supercharger Coolant
Flushing Supercharger Coolant
Cooling Systems Section
Fill and Drain Fill Cooling System
Flush Cooling System
Flush Heater Core
Transmission Section
Remove Transmission (Tranny)
Install 4R70W Transmission (2000 MY)
Steering, Suspension and Brakes Section
Front Suspension and Brakes
Front Disc Brakes
Remove Front Wheel Bearing / Replace Front Wheel Bearing
Rear Suspension and Brakes
Rear Pads
Rear Rotors
Rear Caliper
Rear Dust Shield
Rear Caliper Piston
Rear Brake Adaptor
Steering
Overview
Inner Tie Rod Ends
Outer Tie Rod Ends
Tie Rod Adjusting Sleeve
Sector Shaft Drag Link
Sector Shaft Arm
Idler Arm R and R
Miscellaneous Instructions
Power Steering R and R
Vendor Instructions
Stan Martin Panhard Bar install (Thanks Speedin Bob!)
Old 09-10-2004 | 07:42 PM
Rob_02Lightning's Avatar
AWESOME................
THANKS BRO
(some how I think I'm going to need one or two of them there instructions)
KEEPERS
Old 09-11-2004 | 12:42 AM
BMWBig6's Avatar
Nice!
Old 09-11-2004 | 06:59 AM
01LightninBolt's Avatar
Very informative, there was a few vaccuum lines and electrical connections i didnt see listed though. Did you copy this out of a service manual?
Old 09-16-2004 | 10:13 PM
SVT_KY's Avatar
After my latest escapade, I added Front Wheel Bearings.....
Please note that the FINAL torque spec on wheel bearings is in INCH POUNDS not FOOT POUNDS ... (Wonder how many just kept reading and didn't notice the change in increments ...)
Old 09-17-2004 | 02:57 AM
EP145's Avatar
Great info!!! Whick book did you get it from?
Old 09-17-2004 | 05:39 AM
Fast Gator's Avatar
Nice work
Wish I had time to read them though, off for another 12hr day
Old 09-25-2004 | 03:11 PM
SVT_KY's Avatar
Added Rear Brake info and Panhard install from Stan's
instructions.
Old 09-25-2004 | 05:28 PM
TrackBeast's Avatar
Great info.
Old 09-25-2004 | 08:41 PM
TampaBlack99's Avatar
Great info, will come in very handy in the future. I always wanted to learn how to do my own brake jobs.
Old 09-25-2004 | 09:45 PM
yysenhimer's Avatar
The moderators should add that suff to the FAQ!
Old 09-25-2004 | 09:51 PM
l-menace's Avatar
holy *****
Old 09-25-2004 | 10:05 PM
Don's Bolt's Avatar
Awesome info
you must have more free time than I do, and I didn't think that was possible. hehe
Old 09-27-2004 | 10:06 PM
SVT_KY's Avatar
Added Supercharger chapter for TrackBeast ...
Any other requests??????
Old 09-28-2004 | 12:26 AM
Twisted99's Avatar
header install
Quick Reply: Engine Removal
