Phenolic Spacer Revisited
#46
Don, here is a link to a track test I did before and after the spacer.
These times were set before I added a Built motor. Oh and for comparisons sake the track is at 5500 feet. DA most days is like 7k.
https://www.f150online.com/forums/sh...hreadid=121047
#47
nice
The ET difference could be directly related to the 60ft difference for sake of argument, but your mph was up almost 1 mph on a day that was 1 degree warmer and a little more humid. Does that suggest that the air entering the blower may be a bit more dense because it's not going through a scalding hot plenum?? Maybe.
#48
#50
#51
#52
Originally posted by TrackBeast
IMO any gains aren't measurable. Spacers in quantity cost $5 to make = great profit margin.
JDM also quotes 5-8hp from installing Metco idlers with "superior quality." Metco says that the bearings are the same as OEM. Can anyone explain this? Where are the facts or dyno results?
TB
TB
#53
Re: Re: Re: jesus
Originally posted by LightningGuy
Don't you have handouts to be asking for?
you give opinions on things you have no experience with simply to get attention.
I think you are great... keep up the good work.
#54
hahha
Exactly my point. These hp and "straightening air" claims were used to sell products. Therefore, they need to be documented as evidence. It's called business ethics...you can't just go spouting nonsense about something you're selling unless there's truth in it. I'm just asking for support, but apparently that's too much to ask?
As for the Metco idlers.....do they really use the same bearing as stock for ones??? If so, how come my stock idler pully bolts couldn't be used with them because they pushed right on the seal of the ball bearings??? I'm not saying they are or they aren't, i'm questionining if it's so. I have to use new hardware to mount them???
I would think of the bearing were the same, then the stock hardware would secrue the pulley right on the inner race.
#55
tallimeca,
My graphs are meaningless to this debate because I didn't dyno with it on and off on the same day. I never claimed that..
I am asking a question based on my observation of a weekend of dyno tuning 20 vehicles. Trucks with 4lb, CAI, chip all made about the same. The guys with ported blowers made about the same increase. Everyone that had spacers made right around what the should have without them.
Everyone was doing back to back pulls between 10-15 minutes a part. No one lost the HP and Tq that Gator did between non-spacer runs.
So that is why I am asking this tired old question. I am in search of the truth based on extensive testing. If none exists, that is fine. I never argued the cost of the mod - I paid a little under $50 shipped.
-Mark
-Mark
#56
TB
TB
Hey, now lets not go too far here....I just installed 2 100mm Metcos and granted both bearings inside diameter are not a close tolerant fit...its larger than the factory boss and the pullies wiggles a bit .....but I think I can feel the 8hp right in the seat of the pants it was that or maybe it was the bass in the song I was listening to... but it felt much stronger...
I'll make my own phenolic spacer when I get around to porting the eaton.
#57
If making the air straight made no difference, then jet engines that produce massive amounts of thrust, (75,000lbs or more) wouldn't have inlet guide vanes to make the air flow straighter into the first stage compressor, or stators to straighten the air entering the next stage of compressor or turbine. Air that tumbles, or air that is turbulent, slows down, and you lose efficiency. I am not saying this spacer makes the air flow straight, or smooth. I am just stating a fact that turbulent air is slower than smooth air.
#58
-Mark
#59
Not in my opinion as an airplane mechanic. The guide vanes/stators on a jet engine don't turn the air 90 degrees, they only straighten out turbulent air. I would have to dyno test this mod on 100 trucks to see if the 1 hp is actually there, or if it is just another fuel molecule aligner that clamps on the fuel rail.
#60
-Mark
