While replacing a rear end right axle seal, this came out after I pulled the axle shaft out. when I was trying to get the slide hammer lined up, I pulled it out to adjust the hook and this was pulled out. Any ideas??
That looks to be the spring from the axle seal; it creates tension for the seal to stay tight against the axle shaft. The new seal should have the same thing in it.
