Tow ball / Hitch question...
I know the Hitch has a 5000lb capacity. But can we put a ball in that hole (no pun intended ) that's behind the license plate?
Was that made for a trailer ball?
If so, how much is the towing capacity on that, and is there any reason to use the hitch instead of that?
I ask because I have my hitch taken off (for looks) and it's just sitting around taking up space. I will use it some time I'm sure, but if it's not needed and I can use the ball instead, then why keep it?
-dennis
-dennis
Technically probably yes but just be aware of the tounge weight. The bumper will bend or sag if used to much. Also be aware that if you take sharp turns or back the trailor at a sharp angle the tounge my cut into the bumper whereas if you use the hitch and reciever it is further behind the truck and not as likely to hit the bumper.
Yea what he said ^ I towed alot till I got a hitch for my truck and it is really easy to back up untill you need to repaint the bumper that ball sits pretty deep in the bumper so the turning angle is pretty nill....
Just put the hitch back on and get a hitch cover that says lightning on it.... that is what I done
