Upper Plenum sealing question
After removing the cover plate off the K/B to install the JLP upper plenum I found no gasket but a real thin layer of some type of sealent. Is there any special type or kind to use to seal this?
Check out the size difference between the K/B opening and the stock Eaton opening!!!
wjm
