Rods just came in.. what am I missing for a built motor?
OK lets see here (Just changing rods)
I now have:
H-beam rods
ARP Main studs
ARP Head studs
Rod bearing
Main Bearings
Rod bearings
Need to get:
head gaskets
High volume oil pump
Am I missing anything else? Do I need more gaskets? The oil pan gasket is re-usable right? Any other odds and ends I need to get before I get the motor pulled out? Do I need new rings for the stock pistons? Motor has 30k miles on it.
Thanks, J
I now have:
H-beam rods
ARP Main studs
ARP Head studs
Rod bearing
Main Bearings
Rod bearings
Need to get:
head gaskets
Thanks, J
Sounds about right to me AND CONGRATS BRO
I'm addressing the 3 main issues myself, Rods, Spitting Plugs, and lifting or leaking Heads.
ARP Head Studs
ARP Main Studs
Custom CP Pistons
FMS High Volume Oil Pump
Manley Forged H-beam Rods (we're using something dif, 1200 HP)
ModMax Plasma Moly Ring set
Performance Main Bearings
Performance Rod Bearings
My Heads are having Inserts put in
The New and Improved Head Gaskets from Ford
Motors being Balanced and Blue Printed
A little more Boost, AND A LOT MORE NITROUS
ARP Head Studs
ARP Main Studs
Custom CP Pistons
ford racing sells a head changing kit that includes alot of what you need, you can also find a lower end gasket kit.
www.modularperformance.com stocks alot of that stuff.
ARP Head Studs
ARP Main Studs
Custom CP Pistons
ARP Head Studs
ARP Main Studs
Custom CP Pistons
Originally posted by promodlightning
Rob, I believe the rods your using are the Manley vacume degassed billet I-beam rods with 7/16 bolts. The same ones I have.
was between them and the 850 HP Rods, he mentioned Diff Bolts
Now if he can just make room for me SOON, and get this Mod
moving
Thanks NTIMD8, and of course Best of Luck to You too
