Tire Pressure Monitoring System
you have to cycle the key from off to run 3 times, press the brake pedal, cycle the key off to run 3 times again, the horn will beep, put a magnet on the left front and the the right front valve stems, then start over with the key cycling and do the rear two.
you've got mail with more detailed instructions.
good luck.
later,
chris
good luck.
later,
chris
