Magnum s/c
Re: Magnum s/c
Originally posted by Whitelighting
Hmmm that might be the way to go instead of the port job..will stock motor be able to handle this...whats 1 cost..
JimIII@JDM
732-780-0770
I like the roush suspension. Rides nice, handles great.
Jim, what kind of power could you expect out of my truck with a MP addition? What boost levels does it normal take for a MP truck to break into the 11's. I'd have c&L intake, sbtb, 4lb, e fan, cai, ftvb, 28" hoosiers/truck traks, and i currently use a predator, is that compatible with the MP? i dont hear of anybody using that programmer for the MP. My goal is a high 11 on stock internals. What psi would i need to spin the Magnum? Thanks!
Derek,
The Magnum Powers would be a great choice for you to bolt on a go for 11's. You normally see guys running 11's with the MP with your setup and some full exhaust. You can probably do it without but its more of a saftey procaution to get rid of unwanted cylinder pressure. Im seeing most guys break 11's on about 17 psi which is normally a 4lb lower and MP upper. I feel that with a MP, custome tune, and headers you will insure an 11.
The predator is fine as long as you get a custome tune, I would definatley suggest Sal@PSP for a Predator MP tune or if you dont mind going with SCT we can do a killer tune for you!
JimIII@JDM
JimIII@JDM
1st off jim ill be calling you tried but you must be closed today.Derek do you have a pic of ur trk that i can see what it looks like with the roush suspension ty u both.
JimIII
