i keep breaking traction bar bracket bolts. The pass side front bracket bottom front bolt. I'll replace it then a few weeks later i'll look under and it's gone again.
Stainless Steel? No wonder you bent it. Stainless is weak!
If you do decide to bend it straight, just check the welds at the ends and make sure there aren't any cracks in the welds or paint. You should be good to go.
